rich85704 wrote:
brirene wrote:
Maybe I'm missing it, but I believe the op is mainly referring to whether or not to winterize BETWEEN trips. I'm assuming op understands that he shouldn't have any problems at those temps while actually using it, with proper precautions.
Yeah, that's mostly it. I'd like to avoid the whole de- and re-winterization routine if I'm gonna be on the road again in a few weeks. I've gotten some good ideas from these comments.
In that case, here's how we operate as we use the RV year round. Between winter trips I dump the water (including water heater), blow out the lines with compressed air (40 PSI) and dump some anti freeze in the P traps and prime the (empty) waste tank valves with some. Takes about 1 gallon. When we prep for a trip, it's load with water, burp the system and go. No fuss, mo muss.
That assumes going into unplugged/unheated storage.
