WyoTraveler
Nov 12, 2015Explorer
Assuming since you put it in MH area you are posting about a MH. If your dump valves and tanks are in a heated area you'll probably be OK as long as you keep your heat on. Normally I don't winterize on the road unless the temp drops below 10 degrees but that depends a lot on your MH and if the tanks are heated by your furnace.
