rdascoli's avatar
rdascoli
Winterization issues
i have a 2010 winnebago class C and are having issues winterizing the system. After i flushed out all the water from the holding tank and the faucets are dry i move the bypass to the aintifreeze and when the pump gets turned on the system immediately sucks out the antifreeze without opening the faucets. The antifreeze instead of going to the faucets gets immediately flushed out through what appears to be an overflow outside the back near the holding tank, all of the pink antifreeze is pooled up in our driveway.
I haven't had any issues winterizing in the past few years, i think i may have moved some of bypass for the kitchen & bathroom by accident.
has anyone experienced this before? I don't want to spend hundreds of dollars taking it in to get winterized if this is an easy fix, i don;t think anything is wrong with the system. I looked through the manuals and don't see what i am doing wrong.
i have a 2010 Winn Chalet class C if that helps.
