chevyman2
Nov 10, 2014Explorer
I have winterized a good many Class Cs this year. Not a 14 Freelander though. Every class C that I have winterized has had a open fitting near the water pump (likely under your bed in a small compartment at the head of the bed). This fitting usually has the same plug as an "Atwood" water heater uses for a plug.
Any RV shop will carry an attachment that will screw into that fitting (on one end) and allow you to place the other end over a typical hose (like a garden hose). Then just stick that hose in your antifreeze bottle and turn on the pump.
