Johno02
Nov 20, 2015Explorer
Our 2005 Gulfstream Ultra Supreme has a connection with a rotating tap just ahead of the water pump between the tank drain and the pump. You will need a fitting barb and a short piece of plastic tubing. Gotta do mine in the morning, so if you can't find it, I will post pictures for you. Drain and bypass water heater. close all drains, attach hose to connection, stick hose end into antifreeze bottle, and start pump. Open each faucet until pink stuff runs out. be sure to do toilet, toilet sprayer, and outside shower if so equipped.
