My 07 Yellowstone Cruiser (BT) 5290 has a T drain valve under the bed and next to the water tank. Plus there are 2 valves under the drawers across the coach opposite the foot end of the bed. Suggest you also open the water heater valve and compressed-air blow the system out @ about 40 PSI. Close the valves and pour a couple gallons of antifreeze into the tank and run the pump until you see pink at all the outlets. Then drain the grey tank and add some pink a-frz to the grey and black tanks + the toilet bowl & shower drain and p-traps. Works for me!
