Ivylog
Oct 23, 2016Explorer III
Put air on the hose, it will blow the water out as you open each valve inside until no more water comes out. I use 120 psi air BUT never have all the valves closed at the same time. I make sure the water pump is pumping air before putting air on the city water hose. I only put antifreeze in the P traps and the washing machine... Actually I take it to Fla.:B :B
38,778 PostsLatest Activity: Jun 10, 2026
