garry1p
Nov 10, 2013Explorer
Make sure you only use RV antifreeze.
Your pump is probably OK.
Open the closest faucet.
Prime pump by pouring antifreeze or water into the pickup line.
One trick is if you have enough "in" line push almost all into the AF bottle put your thumb over the end pull it out and hook that end into the "in" side of the pump. This may siphon enough so it will prime the pump.
38,778 PostsLatest Activity: Jun 10, 2026
