Udetective wrote:
So I'm new to RV'ing. I'm taking my Class C out this weekend. During the day, Saturday will be around 50 degrees, but dropping to below freezing at night. I don't have heated tanks or water lines. Do I need to worry about water lines freezing? I'd like to be able to fill my water tank and use the bathroom.
Thanks in advance!
AZ. South TX. MX. This will help that question..:B
IF you are in it, you should be good, but if you have no heat,I still doubt if it will freeze any where serious. It would have to get pretty nasty cold-1 or below before you have real problems. ,,BUT for permanent make sure the whole system is drained and even the hot water tank/s.
Have a great week end.
