JerseydevilExplorer IINov 21, 2016Winterizing water system?Anyone put RV antifreeze into fresh water tank to pump and circulate into lines. Do not have bypass hose from pump to connect to antifreeze bottle.
mbuttsExplorerNov 21, 2016This is what I used before I had an RV with the "suck it up" kit installed: Winterize thru fresh water port
Related ContentWater pump?Why no hot water?No flow from hot water tank Nautilus P1 systemWinterize Water Softener SystemWinterizing tankless water heater
