- OLYLENExplorerI would leave it winterized as is. Might add just a little RV antifreeze to the sinks and toilet and shower just to be safe.
LEN - RVerDianeExplorerI emptied all water tanks last winter so there shouldn't be any water left in the system.
Thanks all for your comments. - BumpyroadExplorerjust drain the water system, no reason to leave anti freeze in it any longer. if there was an issue, it happened last winter.
bumpy - IvylogExplorer III
coolmom42 wrote:
AJBert wrote:
As long as no lines ruptured last winter, you will be fine/
Good point. You should check.
Why? IF...the damage is done and the water is out. Leave it alone and do not worry about it. - coolmom42Explorer II
Good point. You should check. - AJBertExplorerAs long as no lines ruptured last winter, you will be fine/
- dave17352Explorer II
coolmom42 wrote:
You should be fine as is.
x2 - coolmom42Explorer IIYou should be fine as is.
