Hudsoner wrote:
To bring this thread back to life, I have a question, and you might be able to answer it! I cannot tap into the wiring of my toad, because the computers in it will play mad, if they discover anything that is not supposed to be there (CAN Bus controlled)
I just bought a tow dolly that has it's own lights. Doing some research, I found that this is not enough in many states, because my vehicle will be at least four feet behind the lights, and thus requires it's own lights.
The easiest way to achieve this would be a set of the magnetic lights on the back of the vehicle.
I searched Amazon and found that I can get lights for a price between $20 and $300. reading through the ratings, I found that many lights, regardless of their price, have a magnetic base that seems not to be strong enough, and tend to be blown of the toad.
Do you guys have any experience with magnetic tow lights and can recommend some that stay on the vehicle and not get blow to the ground once the setup is moving?
Any advise and information is really welcome!
I have used magnetic tow lights for years, yes the cheap ones will blow off sometimes. The more moderate priced units tend to have stronger magnets. You need units with a 60lbs pull rating or more for the magnets.
