We have used wireless tow lights on our vehicles for the past 7 years now with no issues. Ours take 4 AA Batteries each and are not rechargeable. The Batteries last for at least 10 days of driving, maybe more. I would be leary of purchasing wireless tow lights that only last 8 hours as the ones you posted do. Recharging every day on the road will get old fast. I would recommend you look for ones on Amazon with longer lasting Batteries.
- Grit_dogMay 24, 2025Trailblazer
The Hazard Fraught ones claim up to 100hrs in a charge. li-ion batteries. Seems ok and they’re pretty cheap ($139 seems stupid cheap if they work and you can get a few years of good use out of them and no install effort).
- way2rollMar 24, 2025Trailblazer
You bring up a good point on the run time. I didn't see where it's stated or reviewed that they only last 8 hours. Where does it say that? But yeah, if it's only 8 hours (and run time is certainly shortened with stop and go or running with lights on) You have a link to the one's you use?
On edit; I saw some reviews mention the 8 hours and go further to say that the batteries lose life over time and limit to 4-5 hours. I may go back to the hard wired version that mount in the existing lens. Harder to run, but once set up super clean and just plug them in when towing.
These are the newer versions of the one I have now;
https://www.etrailer.com/Flat-Tow-Wiring-Harness/Blue-Ox/BX88269.html
- IB853347201Mar 24, 2025Nomad II
In Amazon, tap the picture of the lights and then scroll to the right about 4 times. Run time is listed in the top righthand corner.
These are the wireless tow lights I use. Great battery life.
https://www.amazon.com/Blazer-C6304-Round-Wireless-Towing/dp/B00BJEICDS/ref=pd_aw_ci_mcx_mh_mcx_views_0_image?pd_rd_w=BWRQ6&content-id=amzn1.sym.3aeff048-319d-41ad-90b3-930df51a9ea3%3Aamzn1.symc.cb15e6ef-dda0-4490-a93d-da66403ab544&pf_rd_p=3aeff048-319d-41ad-90b3-930df51a9ea3&pf_rd_r=HX0VZN1WKQB7S7GR99WA&pd_rd_wg=iuAmr&pd_rd_r=9145f18e-5302-4fcf-87c5-3486aaab730d&pd_rd_i=B00BJEICDS
