You bring up a good point on the run time. I didn't see where it's stated or reviewed that they only last 8 hours. Where does it say that? But yeah, if it's only 8 hours (and run time is certainly shortened with stop and go or running with lights on) You have a link to the one's you use?
On edit; I saw some reviews mention the 8 hours and go further to say that the batteries lose life over time and limit to 4-5 hours. I may go back to the hard wired version that mount in the existing lens. Harder to run, but once set up super clean and just plug them in when towing.
These are the newer versions of the one I have now;
https://www.etrailer.com/Flat-Tow-Wiring-Harness/Blue-Ox/BX88269.html
In Amazon, tap the picture of the lights and then scroll to the right about 4 times. Run time is listed in the top righthand corner.
These are the wireless tow lights I use. Great battery life.
https://www.amazon.com/Blazer-C6304-Round-Wireless-Towing/dp/B00BJEICDS/ref=pd_aw_ci_mcx_mh_mcx_views_0_image?pd_rd_w=BWRQ6&content-id=amzn1.sym.3aeff048-319d-41ad-90b3-930df51a9ea3%3Aamzn1.symc.cb15e6ef-dda0-4490-a93d-da66403ab544&pf_rd_p=3aeff048-319d-41ad-90b3-930df51a9ea3&pf_rd_r=HX0VZN1WKQB7S7GR99WA&pd_rd_wg=iuAmr&pd_rd_r=9145f18e-5302-4fcf-87c5-3486aaab730d&pd_rd_i=B00BJEICDS
