RayZenExplorerNov 25, 2019Wiring DiagramThe refrigerator isn't coming on, when plugged into 110VAC. I have checked for 12VDC right at the input terminals of the fridge, but there is nothing there, so it's obviously a voltage supply problem ...Show More
cavieExplorerNov 25, 2019Did you check the voltage at the converter with the batteries disconnected? If not you were measuring the battery voltage.you are not gonna get a wiring diagrams unless you have a very high dollar RV.Is there 120 volts to the fridge? Fridge 12 volt control circuit is shared by the furnace and the water heater.
Related ContentAdding power outlets in slide with no wiringWiring diagram - Find my mistakes!Lance 1131 wiring diagramWiring Diagram Help2018 Wolf Creek 850 wiring diagram
