fcooper
Feb 13, 2014Explorer II
Wiring the Bi-Directional Isolator Relay diesel-2
My coach does not charge the chassis batteries when on shore power, it just charges the house batteries.
I'm considering replacing the currently installed Intelletic Relay Delay (charges house batteries when alternator output is sensed) with the Bi-Directional Isolator Relay diesel 2 (BIRD).
The service manual for the BIRD states
The wiring diagram simply shows a connection between the terminal on the BIRD and the generator, but provides no information on where to connect this wire to the generator. If you want to see the wiring diagram I've found, it's at link to service manual
I have searched for installation instructions, but the best I can find is the service manual in the link above.
If any of you have installed one of these Bi-Directional Isolator Relays, can you help me understand how the wiring is connected between the Bidirectional Isolator Relay and the generator. I have a 7.5KW diesel generator.
Thanks
Fred
When the generator is operating, a 12 volt signal is applied to the generator input. This inhibits the isolator from operating. This is to prevent the generator/converter combination from supplying power to the chassis.
functions which might over-load the converter or the generator circuit breaker.
Thanks
Fred
