katysdad
Jan 27, 2014Explorer
backhoemike wrote:
i touched it to the negative and it arc'd so i was nervous about shorting something out. anyone knowledgeable enough to help?
If you are sure the other 2 are Pos cables, and the other is to frame it should be the neg to inverter if so equipped. One large pos and one large neg go directly to the inverter. They do give quite an arc when reconnected.
Like Wallnm said I have not seen a Newmar without a diagram on the battery tray. On units without diagrams I will draw one on the inside of the compartment door with a permanent marker.
38,769 PostsLatest Activity: Apr 24, 2002
