srmurphy
Aug 22, 2014Explorer
On my new battery I have 12V. On my aux I can only get about 3V. I haven't measured voltage on the starter solenoid or terminal yet. It does have a battery cutoff switch. I'll clean it up and see if that helps.
Gjac wrote:
What voltage is at your battery terminals? What voltage is on your starting solenoid? What voltage is on your starter terminal? Do you have a battery cut off switch? I have had mine corrode once and a loose connection once causing a no start problem.
38,776 PostsLatest Activity: May 15, 2026
