allbrandauto
May 31, 2015Explorer
I work a lot on auto electricals first thing I need to now is 60 amp fuse got current on it with key off if yes than current goes from fuse to ign. switch to fuse box you will find your problem to be that wire rub through hitting ground easy way to fix is to look at wire color at 60 amp fuse go to ign. switch and look at same color wire you can tell if its the same wire by seeing if the wire at ign .switch has 12 volts pull 60 amp fuse and test wire at ign. switch again if 12 volts goes away that's your wire cut wire at ign switch and 60 amp fuse and run another wire the same guagefrom fuse to ign. switch
38,776 PostsLatest Activity: May 15, 2026
