wa8yxm
Feb 02, 2019Explorer III
williamp321 wrote:
I have a 2003 Georgetown 346 W22 with a workhorse chassie. Would the piliot relay be in the fuse box under the hood. Thanks in advance for any info.
Yes it would On my RV there are two boxes under the hood One is the "Intelletec Battery Control Center" That is not it.
THe other has no markings. It is dead center at my eye level (6'2" tall me) and the relay's are on the right. bottom relay I believe is labeled "STARTER" (the label is on the inside of the box cover)
If you pull it.. take a White or other contrasting marker and mark the shell onto the base. You can then pry the shell off.. Line up the marks when you restore it.. Else you may get it wrong at lest in the test phase.
It was a not quite freezing drizzle when Mine failed.. I was kind of glad to figure it out quickly because the option was crawling under the @!#$ thing to access the starter solenoid directly.
Yes. I know how to do that too.
