- KilroyGuyExplorerI'm not sure why there is so much excitement about this. Workhorse has never been a "strength" in the RV business. First the hidden brake problems that affected almost everything they built and probably caused accidents. Then they backed out of the business when things got bad, leaving parts availability an issue. I'm not necessarily a Ford guy, but at least we have been able to count on them for over 30 years.
- 427435ExplorerRear engine gassers are more expensive to build than front engine gassers due to the cost of low volume drivetrains and cooling systems for a rear engine.
For a lot less cost, some good sound proofing (like in cars and pickups) takes away the main advantage of a rear engine gasser. - tropical36Explorer
LVJ58 wrote:
Wonder if they'll re-introduce the UFO rear engine gas chassis?:h
When the UFO first came out, I was convinced that it was the future and all front engine coaches would become a thing of the past.
Now, it seems very possible that this could still become a reality. - JetAonlyExplorerI think it is good for the diesel market also.
Regulatory compliance drove CAT out of the market and is making the case for large displacement gasoline/flex fuel engines. Single supplier markets allow Cummins to get lazy and costly with no perceived competition.
That said, in the near term, RV's aren't tied to a known fuel market/location. Gasoline and diesel will be the fuels of choice for a long time. - tropical36Explorer
ronfisherman wrote:
outofplace wrote:
I would assume the 6.0L is the GM Motor
PSI manufacture of the 8.8L also makes a 6.0L engine.
Yes and also 11 - 15 liter forth coming and can't imagine what a beast those will be. Not necessarily that they ever will be offered on a MH chassis, however. - tropical36Explorer
weathershak wrote:
Bring back the ole P32......NOT!!!!:(
I never will understand why the P32 chassis gets so much flak. There
s loads of them out there, going strong and mine with it's 23 grease fittings (maybe more) goes down the road straight and true and along with it's independent suspension, rides pretty nice for an old gas chassis. With better than 90K miles now, nothing is worn out in the suspension, but given, I did upgrade the coil springs and got rid of the air bags. - spud1957Explorer
http://www.psiengines.com/whatwedo/on-highway-engines/ - wolfe10ExplorerSince the Bosch brake recall has been around for years, why would anyone assume they would use pre-recall parts???
Said another way, if there have been no problems with brakes fit/upgraded on Workhorse chassis for many years, why assume that they would re-introduce ones with problems. - Bird_FreakExplorer IIThink the brakes will work?
- wolfe10Explorer
jolooote wrote:
NEVER buy the 1st two years of anything NEW! Wait till they fix the design problems.:E
Other than the engine, wonder how much of the chassis is "new". Suspect it is a continuation of the W chassis.
38,766 PostsLatest Activity: Jan 10, 2026
