MDKMDK
Mar 02, 2018Explorer
pnichols wrote:
How much wear and tear also is related to what chassis is under the Class C ... E350 or E450.
Wear and tear of course afffects other things other than just the engine and transmission. The E450 would have had an easier time at towing than an E350: The E450 has bigger brakes, a lower range rear differential ratio, less transmission clutch slippage due to the lower range rear differential ratio, a larger diameter driveshaft, and thicker metal used for it's frame.
Even if the Class C is on an E450 chassis, wear and tear also has to do with what size the Class C is due to raw weight. A large Class C that was used for towing would of course have placed more stress on all chassis components than a large Class C that was not used for towing.
If the Class C you're considering was around 27 feet, or less, and on an E450 chassis and had been towing only a small toad ... then probably it should be OK from an additional stress perspective.
Agree.
Not a deal breaker, but with caveats.
Without knowing the exact year/make/model of class C and the vehicle it towed, it's hard to say.
Towing is just simple math based on GVWR, GCWR, hitch rating, and weight of the towed vehicle, to name a few. The Ford V10 is/was considered an excellent option in the gasoline engines category for it's durability, and raw power. However, without knowing what it was being used in, and what it was pulling, anything is possible. No engine/transmission combination is immune from abuse, and that would include the Ford V10 combo.
If you can get the numbers and do the math, you'll know better if the towing was well with in the capabilities of the towing vehicle, or pushing the limits.
38,769 PostsLatest Activity: Apr 03, 2026
