dtgunner7 wrote:
Not charging went driving and wants to boil batteries when plugged in, goes from charging wet to agm and overheat signal come on
The inverter would not be charging when driving. The inverter can only charge your batteries when plugged into shore power or running the genset. If the settings on the inverter display are changing themselves you likely have a problem but it could be internal or a problem with your wiring. What kind of batteries do you have. Are they all the same type? What voltage are you seeing before charging starts? Does the charging start in bulk mode and taper down? What voltage are you seeing after the charging starts? What type of batteries do you have? How many amp hours is your battery bank and is the Xantrex set to that rating?
