Tom_M1
Jan 29, 2018Explorer
goufgators wrote:Your alignment guy is correct. That should be 5 degrees caster.
I tried to get the alignment guy to set the alignment at 5 degrees toe in...
My first attempt to remedy the wandering was to replace the front stabilizer bar with a Hellwig bar. This helped a bit. I then had the front-end alignment done with the 5 degree caster. This also helped but improvement overall was slight.
