Sam_Spade
Jan 29, 2018Explorer
goufgators wrote:
I’ve got the tires aired to comply with weight.
Is this a Ford Chassis ??
I had great results with the caster adjustment.
Do a search on here for "caster".
And....what does the above statement mean ? Are you using the tire pressure recommended on the factory sticker ?
IF you are having this problem while towing......there might not be much you can do about it.
