wny_pat wrote:
Yes, you can do it yourself if you have all the proper tools, where with all, and knowledge, but if you do it like you cleaned the radiator, your going to end up at a Cat Shop anyway, so best let them do it for you, cause it will be cheaper if they do it to begin with. No sense in creating work for them.
And how is he going to drive the coach with a broken fan? A piece missing from a blade will create an unbalanced fan creating great vibration. He is taking a chance of the fan really blowing up and putting a hole through the CAC or Radiator.
The way he was cleaning the radiator is the way to do it. That is the only way you will clean the CAC. And he is right about starting the engine and let the fan blow everything out the rear. I do it myself!
