goufgators
Apr 22, 2019Explorer
dodge guy wrote:goufgators wrote:rgatijnet1 wrote:Thanks for reply. No, did not shift anything around.
When you had the coach weighed did you shift items within the coach so that the front axle was close to the MAXIMUM allowable axle weight? A light front end will wander, even if the tire air pressure is set according to the weight.
Yes, it’s the same as a trailer. You want more weight or the same on the front axle as the rear! I just bought a 2012 and it too was all over the road. A 3 hour drive home was a chore. I found out the coach has Hellwig sway bars, Sumo springs and a blue ox true center steering stabilizer. It also has 2 year old Michelin’s all around. I found the tow was out. 5/8 toed out. I reset it to 3/16 toed in. I haven’t driven it since because I have been getting it ready. I’m going to try and get it out this weekend for a drive!
Good luck! If you find the 'magic wand' solution, please let me know.
38,782 PostsLatest Activity: Aug 23, 2026
