way2roll
Apr 22, 2019Trailblazer
zigzagrv wrote:goufgators wrote:zigzagrv wrote:
A couple questions: what is the length of your motorhome and chassis and what are your tire pressures?
32', rear 85, front 90
I meant to ask the wheelbase on your unit, but I'm assuming it is the 208" wheelbase. Also, if you have the Goodyear GS670 tires, they are a harder compound than other tires and can ride a bit harsh. I would suggest dropping the front tire pressure to 85 lbs. Good Luck.
Agreed, a 32' is likely to be well under the weight rating for standard G670RV tires and so the recommended pressure is probably more like 80-82. 90 in the front is going to ride like a brick and be a bit squirrelly. Of course you'd have to validate this by weighing your coach and adjusting accordingly - I see you've done that but 90 seems like you have some extra in there. They probably heat up to 100-110 psi. All that said, the F53 chassis is notorious for handling poorly and amplifying road imperfections. Some is just the nature of the beast. DP is a whole different ball game.
38,782 PostsLatest Activity: Sep 10, 2026
