dubdub07
Apr 22, 2019Explorer
way2roll wrote:zigzagrv wrote:goufgators wrote:zigzagrv wrote:
A couple questions: what is the length of your motorhome and chassis and what are your tire pressures?
32', rear 85, front 90
I meant to ask the wheelbase on your unit, but I'm assuming it is the 208" wheelbase. Also, if you have the Goodyear GS670 tires, they are a harder compound than other tires and can ride a bit harsh. I would suggest dropping the front tire pressure to 85 lbs. Good Luck.
Agreed, a 32' is likely to be well under the weight rating for standard RV tires and so the recommended pressure is probably more like 80-82. 90 in the front is going to ride like a brick and be a bit squirrelly. Of course you'd have to validate this by weighing your coach and adjusting accordingly. All that said, the F53 chassis is notorious for handling poorly and amplifying road imperfections. Some is just the nature of the beast. DP is a whole different ball game.
Yes it is....I have no such issues with my 41' DP. High wind, quartering crosswind......no issues. Maybe it is just the nature of the beast with the F53 chassis.
WW
38,782 PostsLatest Activity: Sep 10, 2026
