jhilley
Feb 10, 2014Explorer
Removing the dinette won't compromise the structure and table and chairs will be a big improvement.
Problem with locating solar panels at a distance from the RV is voltage drop on the PV side. If you locate the charge controller and inverter at the panels and run AC to the RV it will be negligible over a 100' or so.
Sounds like you got a good deal. How are the brakes? I would change all the fluids, oil, transmission, radiator and flush the brakes.
