Kiwi_too wrote:
With a 32" you can use plywood with a side (not top) piano hinge.
Here is Our Install.
I took your advice and converted our 32" bedroom TV to a use a swinging door.
Unlike the 50" TV up front, there is plenty of room for a side mounted hinge. The original 4:3 CRT opening also leaves room for a clock and DVD player below.
I used 3 x 100° Euro hinges to make the door panel flush with the cabinets.
A pair of rare-earth magnets help the door snap closed with minimal effort. There is also a hidden latch at the bottom to lock everything securely when we are moving.
Most import are the horizontal supports near the bottom of the door. They allow the door to rest on the reinforced lower shelf when closed. This creates an unusually stiff mounting surface that doesn't shake or rattle.
Another bonus: the area behind the TV becomes hidden storage that is relatively hard to find.
