happy-2 wrote:
AFTER YOU GOT OUT OF THR RAIN DID THE PROBLEM CONTINUE? If so you mite check your Air cleaner and see if its getting wet from the rain.I believe there was a modification for the Air cleaner so as to not let water get in.Id make a shroud to block the water.
betcha this is the pblm. we experienced the same symptoms as described by the OP. cause was a water-logged air filter. ford did have a TSB (technical service bulletin) for this that involved a shroud for the air filter. our solution was to change the paper filter to a K&N Filter.
