J-Rooster wrote:
happy-2 wrote:
I would Also use some Seafome or stable in the gas tank and run it through the Genarator to help keep water out of the gas.And when you fuel up and park it for awhile put a bottle of Stable in the tank,run the gen till you get home and parkit.
X-2, Seafoam and change fuel filter sounds like you ran some bad gas thru your system IMHO. I had the same problem a while back. Seafoam is $7.00 per can at Walmart 1 can will treat 16 gallons of fuel.
The bad gas can happen when gas sits in the fuel tank for long periods of time.
