Thom1961 wrote:
If you will indulge me with asking another question. I am trying to get some extensions on the dual rear wheels for checking and maintaining the tires for proper air pressure. The way the tires are placed, the valve stems are impossible to get to, both inner tires and outside. What do you have to do to get the hub caps off, or do they come off at all? What about the bolt covers and center of the hub? My brother and I have tried to crow-bar them off, but they seem stuck from the center. Tricks? Something we're missing?
Thank you for the welcome, by the way! You guys rock!!!
Tom
Look for two nut covers opposite each other that do NOT have the small flange on them that the rest do. Those two will unscrew from an adapter that's screwed onto the stud ends after the lug nut. Removing those two "odd" nuts will allow the wheel cover to be pulled off, and removing the adapters will allow the wheel to removed normally.
