Red Max Pro and ZEP are a floor finish. True, but think about the wear a floor gets between applications of finish. This is intended as a time and labor savings thing to do, and it does it.
The Clear coat on the front cap, on our MH is peeling from bug strikes. This is a top of the line 5 Star clear coat finish, and I am heart broken. It was final washed, then wet-sanded starting with 400, and ending with 1,500 wet/dry paper, then wiped down 2 times. Then it was masked, a big job in itself, including all decals, then a final wipe-down with thinner, before spraying. I have done this type of painting before, but am at a loss to explain why the clear coat is peeling. The bug strikes cause a small craze, that apparently causes a lifting of the clear, and then it can be pulled off in large sections. The back end cap has not had any problems as of this date. The front cap looks stellar, where it is not peeling. This product was/is being used for its intended purpose, but still failed. When I get all the clear coat off the front end cap, I will Zep it.
