royl's avatar
royl
Zep wax problem
I did the Zep floor finish process on my motorhome last fall. It looked great but now I am in the desert southwest and the wax is turning white and peeling off only on the stripes on the sides of the motorhome. It is still fine on the white where it stays cooler but on the dark gray stripes it is peeling bad. Any ideas? How could I remove the wax on the stripes and not affect the white parts? I would hate to start a whole new process.
  • I suspect something is wrong with the prep done before applying the Zep. I live in south TX and applied Zep to my 5th wheel 14 months ago. It sits in full sun year-round and there is no sign of peeling on any surface, including "stripes" and decals.
    I'd suggest buying some Zep floor stripper, testing a small area to be sure it works without removing your stripes, then use it to remove the flaking Zep areas. Ammonia may also work.
    If it were me I would then use Barkeeper's Friend to be sure everything was off the flaked area, wash the entire RV with TSP, rinsing thoroughly before allowing to dry and re-ZEPing the entire RV. You will have to apply several coats (4-5) on the stripped area, but one coat elsewhere will probably do the job.
  • I too was going to do the Zep wax thing, then I read how heavy exposure to sun can make it peel. I did some reserch and found that Zep does not have UV protection. I came up with Polyglow, originally made for boats. Just finished it this weekend, looks great.
    You might be able to recoat with Polyglow.
    Ken
