PA12DRVR
Dec 24, 2014Explorer
Couple of thoughts from the designated prime rib cook in our extended family:
- The importance of having the roast at a uniform temperature to start with cannot be overstated.
- Note that I didn't say "room" temperature ....room temp is good but my favorite prep method starts a bit below room temp.
- Favorite prep method is to cover the roast in a mustard-pepper paste made primarily with (duh!) brown mustard, cracked pepper, some salt, and a dash of Worcestershire sauce: for this method, thaw the roast in the fridge until it is ENTIRELY thawed. I then put the paste on and put the roast back in the fridge for at least 8 up to 24 hours.
- After sitting in the fridge, I pull it out an _____ (hour, 2 hours) or so before starting to cook and let it get to circa 50 degrees (measured with an instant read meat thermometer.
- At that point, the roast goes in the (oven/BBQ) set at low-ish temps. When I BBQ, I try to have the chamber at 275 - 300 for the 1st 30 minutes then drop it down to 225 - 250....same thing in the oven, but the 1st 30 minutes are at 325 - 350 then drop down to 250 - 300.
- I pull the roast out when the internal temp in the thickest part of the roast is circa 15 degrees below the "rarest" that I want. Roast then rests under loose tenting of foil for at least 10 maybe 20 minutes....enough to (pending the size of the roast) let the internal temp rise that last 15 degrees.
Carve and serve....the mustard paste has made a great crust to keep the moisture in and is good for "crackling" if one enjoy's a snappy taste.
FWIW, although I recognize the value of the originally posted recipe, I simply couldn't bring myself to turn the heat entirely off. Simply goes against the grain of long slow even low heat that IMHO provides the right conditions to cook a nice cut without drying it.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
