Compare this recipe to yours....I have made this delicious relish for fifty years and never used the hot water bath, and all four of my daughters make it every year in the same way.
If the ratio of vinegar and sugar is sufficient to make a pickle, and as long as you aren't using meats or low-acid vegetables, it will inhibit growth of harmful organisms. Be sure to boil your jars and lids for at least 20 minutes, and keep them in the hot water until ready to begin filling. Cap immediately with the sterile lids and it will keep for years.
Green Tomato Relish
4 cups ground onion
4 cups ground cabbage
10 green tomatoes, ground
12 sweet green peppers and 6 sweet red peppers, ground up
1/2 cup kosher salt
Combine all the vegetables in a glass or stoneware bowl (do not use metal). Sprinkle the salt over the top and let stand overnight.
In the morning, first boil your jars for 10 minutes and leave in the hot water til the relish is ready.
Drain the vegetables and rinse thoroughly and drain as completely as possible, pressing the relish down with a spoon to get ris of the water.
Combine and pour over the vegetables in a stainless steel pan:
6 cups sugar ( This is the original recipe; I use 2 of white and 3 of light brown)
1 TB. celery seed
2 TBS. mustard seed
1 1/2 teasps. turmeric
1 quart cider vinegar
2 cups water
Heat to a boil and boil gently for three minutes. Pack in the hot sterilized jars and seal. It is useable right away but best after at least a month. It keeps for years
A bad day camping is better than a good day doing anything else.
