don1911's avatar
don1911
cast iron damaged?
I have acquired some cast iron conbread fritter pans, and small skillets. Someone "removed rust" with "Evapo-Rust" chemical. The chemical is supposed to be a safe way to remove rust, so maybe its not the problem. Or maybe it is. I don't know. However one of the skillets had paint on it. All the cast iron was soaked in same container at the same time for at least a day, maybe more?. Then I acquire them. And I cleaned and seasoned them. Now my cornbread tastes funny. Can they be "cleaned" of whatever is causing bad taste? or are they ruined?
  • You can accomplish the same heat level if your oven has a "clean" cycle. But, it will smell up the house.
  • Johno02 wrote:
    Throw it in the campfire, and heat to red-hot. Remove carefully and let cool.
    I'm not sure you can get it red hot, but get it as hot as possible.
  • I've always understood that cast iron needs to be heated slowly and cooled slowly. Thus, let your heat source go out and die. Take you pans out of that place after they are cooled to the air around them and you.
    :C
  • x2 what Johno02 said...
    no need to use chemicals you can clean/restore even the worst condition cast iron with heat and oil. A good hot fire will turn the rust to dust and burn off anything on it, bury it right in the coals when you heat it. The rust should just wipe off with a green kitchen scrubber after it cools. When you reseason with oil and heat a second time, it will look and work good as new. I have heard of people passing the same pan down for generations and they still look/work like new. I have also heard of people finding old pans that have been sitting in a shed for decades and are covered in rust and making them like new again.
    I think the only way you can ruin it is by cracking it.
    Once restored, never wash it, just wipe it off with a green kitchen scrubber. For really stubborn messes if you really must, use a small amount of soap and scrubber and after rinsing put it back on the burner to dry however you may have to reseason it more frequently.
  • Johno02 wrote:
    Throw it in the campfire, and heat to red-hot. Remove carefully and let cool. Reseason as recommended. If that doesn't fix it, call Lodge cookware in Tennessee.
    x2 - heat it until it starts smoking and then stops smoking, burn off whatever mistakes the previous owner made.
  • Throw it in the campfire, and heat to red-hot. Remove carefully and let cool. Reseason as recommended. If that doesn't fix it, call Lodge cookware in Tennessee.
