jbrowning's avatar
jbrowning
Cast Iron Skellet Cleanup Question
So when you are out camping how do you care for your skillet? When washing them out, if there is grease in it (like hamburger grease you can't save) do you let it go into your gray tank or would that cause damage to the tank?
Thanks
jim
  • I have been washing cast iron pans and pots with liquid dish washing soap for nearly 50 years with nary an ill result. I don't get the "don't wash it" thing. :h
  • I do not ever use soap. I use HOT water and I pour it into the skillet while it is still hot. Let it sit for a few minutes then scrub it out with a plastic scrubber, rinse, wipe dry, spray with PAM, wipe excess off, and store. My skillet has a very smooth patina.
    And no, do not put grease into your gray tank. pour off the grease and wipe out the rest.
  • If this is a REAL CAST IRON skillet, you should never wash it unless in extreme circumstances because if you do than you need to go through the process of seasoning it again. I scrape if necessary and then wipe out with paper towel.
  • dbbls wrote:
    I wipe out the grease with a paper towel and dispose of it in the trash. I never let grease, or any food waste, into the holding tank.
    Very good point. ;)
  • I wipe out the grease with a paper towel and dispose of it in the trash. I never let grease, or any food waste, into the holding tank.
