Kit Carson wrote:
the bear II wrote:
I find some sand and add water to create mud and then use that to clean the outside and the inside. Learned this in the Boy Scouts. Then you wash it with soap and hot water and rinse.
At home I often use a brillo pad on the outside. Learned this from my mom.
You use soap on cast iron??
Nothing wrong with using soap on cast iron. The OP is after all is cleaning the outside.
For the inside, I use vinegar and a scrubby pad, rinse in hot water then heat it a bit and coat with peanut oil
