- littlemoExplorer
bigred1cav wrote:
We sit our Keurig on table for use. In sink for traveling.
X2 - bigred1cavExplorerWe sit our Keurig on table for use. In sink for traveling.
- mdamerellExplorerReally comes down to personal priorities. Some are more picky about their coffee than others. Our Keurig sits on the counter by the door. There is a little triangle behind the sink that was "wasted space". The Keurig sits well in there and I have access to the cabinet I keep the 1 gallon jugs of "coffee water". I can easily step inside the camper to get a "heater".
- wbwoodExplorerAnd by the way, the Melitta cone is only $5 on amazon including delivery. It's plastic and lightweight. No issue of breaking.
- wbwoodExplorer
jake2250 wrote:
We use Starbucks Via's, very simple and good coffee for instant. Got the Melitta pour over for Christmas,found it to be very slow and coffee was weak. Just got a french press yesterday and had a couple of cups of very rich delicious coffee, going to get another for the trailer. We also camp with out hook ups so we don't use a coffee machine!
How can the melitta pour over be weak? You control the amount of coffe grounds you put in it, just as you would a regular drip coffee maker! Slow? It takes all of less than a minute to drip. - jake2250ExplorerWe use Starbucks Via's, very simple and good coffee for instant. Got the Melitta pour over for Christmas,found it to be very slow and coffee was weak. Just got a french press yesterday and had a couple of cups of very rich delicious coffee, going to get another for the trailer. We also camp with out hook ups so we don't use a coffee machine!
- fla-gypsyExplorerIt's all about priorities for us. Coffee machine has permanent spot everything else is temporary.
- JiminDenverExplorer IIWe have a small Rival 12 cup thatdoesn't take up too much space. ($6 at Walmart) No fancy stuff, just a on/ off button. Run low on power and we can heat the water on the stove and pour it over the grounds manually.
- jfkmkExplorerYeah, where to put the coffee pot can be an issue. We have a small counter top above our fridge we put it on.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
