- wbwoodExplorer
qtla9111 wrote:
My favorite:
Collapsible Java Drip
nice...basically same as the Melitta, but collapsable... - BumpyroadExplorer
BajaLinda wrote:
We had a under the counter drip. Loved it. the pot never did jump out going down the road. If we had no electricity and didn't want to turn the generator on we had a tin campfire coffee pot, used it on the stove.
our B&D under the counter had a velcroed strap across to hold the pot in. had to put a wash cloth under the pot or it would drive you nuts with the rattling.
bumpy - qtla9111Nomad
- steve-n-vickiExplorereasy I don't drink coffee, but I do have a small cheap coffee maker that fits in a lower cabinet
- cpd520ExplorerI enjoy French Press the best, it is just a little messy to clean up. We use Aeropress with the stainless steel reusable filter. You still control water temp, coffee amount/grind and steep time. Almost as good as French Press and no mess.
- The_Mad_NorskyExplorer
littlemo wrote:
bigred1cav wrote:
We sit our Keurig on table for use. In sink for traveling.
X2
X3.. OK, almost.
We are such coffee fanatics, we have the Keurig. We also have the Starbucks Verismo brewer.
And we carry both along when traveling. Both fit in the sink for travel safety. - BajaLindaExplorerWe had a under the counter drip. Loved it. the pot never did jump out going down the road. If we had no electricity and didn't want to turn the generator on we had a tin campfire coffee pot, used it on the stove.
- 2-MTnestersExplorer
Lantley wrote:
fla-gypsy wrote:
It's all about priorities for us. Coffee machine has permanent spot everything else is temporary.
Agreed my Keurig has a permanent spot on the counter.
Same for us. Won't be without our Keurig. - LantleyNomad
Agreed my Keurig has a permanent spot on the counter. - jesseannieExplorerWe use a Melitta pour over adapted to a 10 cup insulated carafe at home and a quart+ size thermos on the road. It makes absolutely the best coffee. You get the water hot enough (which any auto drip will not). With the thermos I can take it out under the awning outside and it stays hot. Then if it is a travel day it goes in the truck.
Good coffee is a HIGH priority for me and my lovely and this is the best.
After you make it dump the grounds and the little plastic Melitta cone goes in the coffee drawer.
Easy peasy.
jesseannie
About Chefs on the Road
2,136 PostsLatest Activity: Jul 25, 2025
