- magnusfideExplorer III
JaxDad wrote:
magnusfide wrote:
No reason not: just be sure of the slow cooker's amp usage so that it does not push too many while AC or other appliances are running.
I'm not sure that's much of an issue, even the big slow cookers on high are still only 250 watts, a smaller (3 qt) slow cooker on low is only 70 or 75 watts.
Notice I wrote "not push too many while AC or other appliances are running".
There are situations I have seen where occupants will be running a number of appliances all at once and end up with an overload when plugging in a small usage appliance. The virtual straw that breaks the camel's back.:W - JaxDadExplorer III
I'm not sure that's much of an issue, even the big slow cookers on high are still only 250 watts, a smaller (3 qt) slow cooker on low is only 70 or 75 watts. - Sourdough_BiscuExplorerSpeaking of crock pot cooking while on the road... we found a 12v crock pot at a truck stop. It's a great way to cook if you have a long day on the road. Just pull in and dinner is already cooked!
- billkaufmannExplorer
RuthieT wrote:
Is it ok if parked all day at Campground to have a crockpot plugged in with dinner cooking??
Used to do it often. No problem. Now we use the NuWave oven. We really like it. - MerrykaliaExplorer III do it all the time......lasagna is one of my family's favorites. Also do a curry chicken, chicken pot pie and a chicken casserole.
YUMMY!
Nothing better than being out hiking, boating or whatever all day and come back to dinner ready for us to eat right then - Ron3rdExplorer III
We've done that many times, no worries. - FliposoExplorerLeaving a Crockpot cooking outdoors, unsupervised, might result in a ticket.
- magnusfideExplorer IIINo reason not: just be sure of the slow cooker's amp usage so that it does not push too many while AC or other appliances are running.
- mpierceExplorerI use a small crockpot in my semi. Use inverter. 100 watts. Cook up small roast with potatoes, onions, and carrots. Makes two meals for one. You could do the same in a trailer.
- rockhillmanorExplorer III
RuthieT wrote:
We have a fifth wheel toyhauler, so that probably wouldn't work. But If its ok at least when camping multiple days then that would be great.
I have a MH and when parked I just put it outside on a portable little table and plug it in directly to the shore station to the 15 amp outlet.
That way it doesn't trip the GFI when I use something else in the MH.
About Chefs on the Road
2,136 PostsLatest Activity: Sep 09, 2026
