- Super_DaveExplorer II
propchef wrote:
Super_Dave wrote:
I used to be a big user of my oven but have slowly started to use the convection oven in the micro more and more.
How are you liking that?
I'm ordering one.
It sure beats getting on the hands and knees to start the oven. The convection just takes a little getting used to but does a fine. - propchefExplorer
I'm ordering one. - Super_DaveExplorer III used to be a big user of my oven but have slowly started to use the convection oven in the micro more and more.
- I think if you run your fan at home when you cook, you'd prolly want to run you fan in your coach when you cook. Also, in my opinion it would depend on what you're cooking. Frying something.....yes, boiling something..yes to remove moisture. As mentioned earlier, a fantastic fan can also remove steam, moisture from boiling water faster and quieter than the kitchen fan. I like to run the fan when cooking bacon or sausage. That way the neighbors can smell the yummies. Now if they're Vegans.......They can smell my coffee perking.........Now, if they're Vegans that don't drink coffee........I have a larger challenge in front of me!
- BurbManExplorer III
- wopachopExplorerIf you have time and desire to tinker around theres a chance the microwave fan is 12v. You could power it from a nearby lighting circuit so its works off the battery.
- Sjm9911ExplorerEaither smoke is good as long as it works. They will both give you plenty of time to get out. And make up air with anything that burns is good advice. If you use your fan, make sure you open it on the outside. Many have a latch or push pin that the fan motor cant open by itself. So if yours isnt working check that. Mine works ok. More reasons to cook outside.
- ICamelExplorerAnd for another point to consider. You might think differently if you have a CO detector with a digital readout. The only time it has gone off in any of our RV's is when the oven was on and no ventilation.
I do have a digital readout CO detector and the amount of Carbon Monoxide generated by the oven is scary. Probably why they have a warning about using the oven for "comfort heating".
If you don't want to run the fan, just leave a couple windows open slightly(1/4" to 1/2"). You will be fine. - ReneeGExplorer
RobWNY wrote:
ReneeG wrote:
In RV's wouldn't it be safer to use an ionization type smoke detectors especially since RV's burn faster?
Someone smarter than me should probably answer that question but in my case, the smoke detector still goes off quickly if there's any smoke from cooking. So now, instead of going off EVERY time we cook, it only goes off if we burn something.
Makes sense. Thanks. - ReneeGExplorer
BurbMan wrote:
ReneeG wrote:
Since we dry camp most of the time, we don't have ability to run the fan...
The light and the fan on the range hood work on 12v, so it should work just fine even when boondocking.
For the OP, you only "need" to run the fan to exhaust smoke or odors, same as you would at home.
Our light and fan is in the over the range microwave and hence not 12V.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
