- I would say that Charcoal is always my favorite. But there are a lot of RV parks that Charcoal can't be used so gas grill is a necessary evil(my opinion, not looking for a fight) and I have one. I ran a separate line off the coaches gas system to feed the gas grill. I still keep a couple small bottles to feed the gas grill if I needed to move the grill to a locations that the "trailer system connection hose" won't reach. Best to have a couple options on hand.
- TANDDANDBIGEExplorerI really like my Weber Q2000; even heat and very adjustable, but no "indirect cooking" though. I clean it thoroughly when ready to pack up; I keep it in a large tote with lid. This way, there is no smelling up the basement and anything else stored there.
- Shadow_CatcherExplorerWe have identical small gas grills that we use at home and with our teardrop trailer both are tank supplied. The one used with the tear has a Bullfinch gas point I imported from the UK and a ten foot hose with gas quick disconnect.
There are times and locations where fires are not allowed that may include charcoal. - nineoaks2004ExplorerI have a grill and a Coleman stove that I converted to LP gas, I carry a separate bottle of LP and a long hose to use for these two. I usually set them up side by side on a picnic or metal folding table as I like to do most of my cooking outside (weather permitting) I also carry a tripod and cast aluminum pots for "over the fire cooking"
- NYCgrrlExplorer
ThruTraffic wrote:
I want to get a small outdoor grill for steaks, burger, shish kabob, etc.
Would you use charcoal or propane?
If using propane would you get a separate tank or use a tap off the main tanks.
Figured cooks would know better about this.
I think it's a matter of preference.
I prefer the taste of food cooked over charcoal and wood.
IMO the clean-up time is pretty much the same whether you cook on your S+B's range, a gas or charcoal grill. Just mindless drudgery; nothing special.
After using several Weber charcoal products, a patio sized kettle, Smokey Joe (the one with an ash can), and Go Anywhere, I've decided that the GA better fits my needs. There's a learning curve w/ it since it lacks the depth of a traditional kettle shape but I think I know it's lil quirks now. - the_bear_IIExplorerwe used propane grill with it's own tank. A small 1 gallon tank we bought at an RV supply store.
Now we use an electric grill my DW bought from QVC.
http://www.qvc.com/Masterbuilt-Veranda-196-sq-in-Electric-Grill-with-Cover.product.K41863.html
It's convenient and flavors as good as any grill we've used...charcoal or propane. We carry it in the shower - KD4UPLExplorer IIPropane because it's easy, quick, and cheap. Separate tank for the same reasons.
- GoPackGoExplorerThe words propane and charcoal should never be mentioned in the same sentence.
I started out with a Weber Q and it worked fine BUT . . . I really missed the great smoky flavor I got from the charcoal grill I used at home (I fulltime now).
So I got the Weber charcoal Big Joe and cannot be happier. It has a swing arm that comes up and holds the lid in place for travel. I just dump the ashes, slide it into a big garbage bag, and put it in my basement (fifth wheel) for travel. The smaller version would work fine too, but I wanted that 'lockable' lid feature. I just need to get a hinged grill for it so I can add charcoal while cooking.
I keep a bag of hickory chips and one of mesquite handy; soak a handful of chips in water, and place on the charcoal just before the burgers or steaks go on. YUMMY !
Cooked a great tasting tri-tip on it just last Sunday. I just don't believe it would have tasted as good if cooked on a gas grill.
Weber sells a really nice portable table that locks the grill in place on top so they won't slide off. Their site details which grills will fit on it. The legs are removable and store under the top for travel. Works great for my Big Joe. Bought it thru Walmart.
I also carry a pellet grill. Really like that thing too.
Life is just too short to not make great tasting food. - At least here in WA State and the State Park campgrounds we go to during the summer, if there is ever a burn ban, you can't even fire up a charcoal BBQ.. Gas only in those cases..
Got my propane stove and firepit for those times! :)
good luck!
Mitch - cyntdon2010ExplorerAt home we use gas mostly. because I am in a hurry. But
when camping its no stress and time has no place on the campground. charcoal is
best, flavor smokey
About Chefs on the Road
2,136 PostsLatest Activity: Sep 09, 2026
