BobsYourUncle's avatar
Aug 25, 2021
Rusty grille - How to avoid
I am very fussy about cleaning my BBQ grille after every use. It has your typical cast iron cooking surface.
I clean it thoroughly, scrape off excess food, burn off all residue and follow that with the wire brush treatment until it is clean.
Challenge is, the grille rusts, especially after spending the winter stored in the pass through compartment.
Before each use, I thoroughly wire brush it again to get rid of any old remnants and then brush on olive oil with a silicone brush on the entire surface. Then I burn off the excess oil until I have a hot, rust free surface to cook on.
There must be something that can be done to avoid the rust. Leaving a dirty greasy layer of old dead food does not appeal to me. My home BBQ has a stainless steel grille and it's easy to keep clean.
What do you guys do?
  • For me, the heavy scrap and clean is before each use. Preheat the grill on high and stuff comes off easily, no rust.
  • Spray with Pam before each use.
    Don't clean it so fastidiously. Don't burn off the olive oil.
    If the cast iron grill will fit in an oven, you can season it the same way as a cast iron frying pan. Use a "high heat" oil such as walnut.
  • I leave a dirty greasy layer of old dead food and when I do clean it off no rust.
