- parcanyExplorerKingsford original for me
- garmpExplorer IITom Trostel;
Thanks for the link. Never knew that. Very interesting. - OkieGeneExplorer
fla-gypsy wrote:
Kingsford original is my go to and I add wood based on meat
Absolutely! And I prefer the original. - Tom_TrostelExplorer
- Rolling_CondoExplorer II
magnusfide wrote:
I use the Kingsford original. It's an easy start, reliably holds the heat in a steady burn and lumps last a bit longer too without going out. A chimney starter is always a good investment for better starts as well.
That sums it up for using the original. Most important for using when cooking with Dutch Ovens as you want constant and consistent heat. - coolbreeze01ExplorerOriginal when I use charcoal. I add either hickory or mesquite for flavor with gas or charcoal.
- RandACampinExplorer IIKingsford original 90% of the time. Kingsford Mesquite when doing whole turkeys on the grill.
- Need-A-VacationExplorerI haven't noticed it. Will try to watch for it next time I use the WSM.
- GordonThreeExplorerHas anyone else ever noticed the fine gravel in the ash? I wonder where that comes from, if the charcoal is supposedly 100% hardwood? The hardwood trees around my area don't have any gravel in them.
About Chefs on the Road
2,136 PostsLatest Activity: Sep 09, 2026
