SteveRuff wrote:
martipr wrote:
SteveRuff wrote:
Let's get a new thread with Weight Watcher recipes only. Be sure to list points/and or calories so we can all keep track. I'll start off with this one.
Baked Coconut Shrimp
1 1/2 pounds Shrimp - Extra large, defrosted, shelled and deveined, rinsed and patted dry
1/3 cup cornstarch
1/2 teaspoon ground red pepper
salt - dash
1 tablespoon honey
1 tablespoon lime juice - fresh squeezed
1/3 cup egg whites
3/4 cup coconut
Preheat oven to 425° F. Lightly spray a large baking sheet with butter flavored cooking spray.
In a small bowl combine cornstarch, pepper & salt. In a small microwave safe dish heat up honey approx. 30-45 seconds
Add lime juice to honey and stir. Slowly add in egg whites and continue to stir.
Place coconut in a thin layer on a pie plate or flat dish.
Take each shrimp and first dip into cornstarch mixture, then in egg white mixture and finally roll in the coconut.
Place on the baking sheet and lightly spray with butter pam. Bake 10-15 minutes or until shrimp is pink and the coconut is lightly toasted.
Per Serving (excluding unknown items): 230 Calories; 10g Fat (42.3% calories from fat); trace Protein; 31g Carbohydrate; 2g Dietary Fiber; 0mg Cholesterol; 96mg Sodium. Exchanges: 1 Grain (Starch); 1/2 Other Carbohydrates.
WW Points:  3 servings at 5-P each OR 2 servings at 7-p EACH
I fix a sugar free peach jam with a liberal amount of grated horseradish to use as a dipping sauce. nAdd points accordingly.
I believe that Shrimp has approx 144 gm of protein per 1 1/2 pound, considerably more that a trace per serving.
Not sure what your point is with this post. When I have posted recipes including points I have taken the point counts directly from the WW site. I will grant you that some posts, especially the earlier ones, were from the original point system and will vary from what WW uses now although I have tried to update my recipes when I can.
I did not mention points. I don't know anything about points. My comment was about the post showing only a trace of protein, which I think was wrong. It was in no way intended as a bad mouth, just a correction to a possible error. Thanks for a really good recipe, I am going to try it soon
