ol_blue1's avatar
ol_blue1
Yummy Baked Breaded Pork Chops
This is so easy to make and just season the pork chops to your liking.
Enjoy! Debbie
1 pork chop
salt
pepper
sage, dried
garlic powder
2 tablespoons dry bread crumbs per pork chop
butter, to dot
apple juice
Line a baking tray with foil and lightly grease the foil.
Place as many pork chops that you are wanting on to the baking sheet.
Sprinkle the top surface of each chop with some salt, pepper, sage and garlic powder to taste.
Then sprinkle a tablespoon of bread crumbs evenly over top of each pork chop.
Dot the pork chops with butter.
Pour apple juice into the baking tray evenly around the chops, trying not to disturb the crumbs on top.
Place pork chops in the oven and bake at 400 degrees for 15 to 20 minutes, checking to make sure the apple juice does not boil dry in the pan.
Once the crumbs have begun to brown on top, remove the pan from the oven.
Carefully turn each chop over without disturbing the crumb topping and repeat the process for seasoning and crumbing on the underside.
If you need more juice in the pan, once again pour it around the chops.
Return the pan to the oven and cook for another 15 to 20 minutes, or until nicely browned on top and the juices have thickened into a bit of a sauce.
Check every 10 minutes or so to make sure the pan is not going dry and top up with more juice if need be.
Serve hot with some of the pan juices spooned over top if you want. My husband did not top his with juice and he loved it.
